Old 05-26-2018, 10:14 AM   #2
JBauer
JBauer's Avatar
Originally Posted by Brian in Tucson View Post
There are two adjustment points and you can see them both in your picture. You can use the linkage on the other side as a guide to get it close--then use the bolt shown at the bottom to get the linkage adjusted to a correct position.
Unfortunately both sides were unhooked when I removed the soft top. ��
