Old 05-25-2018, 03:44 PM   #12
Gilles
Whiteyll, considering that the car is already 20 years old, I would recommend to replace the rubber hose that attaches to the slave cylinder as these, when they fail (internally) don't show it outside, unless you get someone to push the pedal while you watch if the hose 'ballons' under pressure.
This is a common failure on the slave cylinder of the Alfas with a transaxle, also new hose should not be expensive.
Good luck!
Gilles is offline   Reply With Quote
