thank god, somebody with an actual lead! thank you, i will make this happen, you just gave me a bit of direction in a vast sea of people that seem to think the only possible option is factory replacement
Originally Posted by 78F350
As the others have replied there is no open knowledge on this forum of how to completely delete the immobilizer. If there was, a bunch of us would be doing it and discussing it.
Cheap and ugly: It can be minimized by still using all the main components and eliminating the rest. Duct tape the DME, CLU, transponder coil & transponder together with a minimized wire harness. Post 79 here shows the minimal wiring for the Central Locking Unit box: https://rennlist.com/forums/spec-boxsters/914070-black-spec-boxster-build-6.html
Expensive, but clean: Pay a shop that has already hacked the DME security, have them reflash your DME. I don't know of any shops that do this, but ECU doctors has a similar service adding a module to replace the immo. Immobilizer Removal for Porsche Boxster ECU DME 0261204605, 0 261 204 605 - Specialized ECU Repair
Good luck and if you have a break through or find a reasonably priced reflash, let us know.
