Old 05-24-2018, 05:12 AM   #1
AZ986S
AZ986S's Avatar
Here are a couple pics of the fronts.
Looks like the trailing edge is thinner in my case...
No noticeable difference between average thickness of inner and outer pad.
And yes... they are pretty cooked!
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
