Old 05-22-2018, 12:19 PM   #1
MWS
Have you tried using a bent piece of metal inserted through one of the holes in the panel to gently lift upward while turning the bolt? This might apply enough tension on the nut to stop it from spinning. Be prepared though...if the captive nut is free and you remove the bolt, the nut is going to fall somplace...
