Probably toast. You can drain and inspect the fluid. If it looks nasty and/or is filled with sparkly stuff, game over. A used AT from a dismantler that has clean fluid will probably be less than 1/2 the cost of a rebuild and will often be a good choice.
https://www.pelicanparts.com/techarticles/Boxster_Tech/35-TRANS-Auto_Fluid_Change/35-TRANS-Auto_Fluid_Change.htm
