Old 05-17-2018, 05:09 PM   #18
The Radium King
The Radium King's Avatar
at this point, perhaps just confirm that the dme has power and see if you can pull an obd signal direct from the unit. here's what i have for 2002 pinouts for that connector:
Connector I, 9-pole
Pin Designation Pin Designation
1 Terminal 15 - switched power
2 Terminal 30 - always on power
3 W-wire - OBD
4 Ground, electronics
5 Ground, fuel injectors
6 Ground, output stages
7 Throttle motor actuator
8 DME relay terminal 87 - pretty sure this is permission from immobiliser to turn on
9 Throttle motor actuator
Last edited by The Radium King; 05-18-2018 at 02:37 PM. Reason: just to note that these are for a 2002 996, not 986 ...
