Old 05-09-2018, 03:36 PM   #4252
dav9515
/\ love the updates to the car!
today i installed:
3 spoke wheel
997 shifter
ECU Doctor Water proof immobilizer case
easy to do them all at the same time, disconnect the battery, and with the seat removed the center console was a bit easier to deal with. I've owned the car for about 8 months and every time you do work on a car you learn some things. I learned:
1. under the seat was COMPLETELY dry, it doesn't appear water has ever gotten into the cabin or on the carpet - Knock on wood
2. the center console was definitely removed before as there were some screws missing and the shift know came off very easily.
3. there was a collection of dirt and acorns under the center console. Tells me at some point there may have been some unwanted tenants residing in the car. Luckily all the wiring and carpet looked fine so whatever brought that stuff into the car seems to have vacated without causing any damage - knock on wood again!
dav9515 is offline   Reply With Quote
