Originally Posted by jandr95
Installing new ATE vented front rotors on my 02 Boxster S and discovered a severe wobble in the left rotor. Reinstalled it several times, still there. I removed it and checked the runout at the hub and it was negligible so I'm sending the rotor back. It must be warped. I'm a bit surprised. These are not bargain-basement rotors. Then again, they're not super-expensive OEM either. I have a replacement on the way. Is this rare? Or not so rare?
May simply be from improper storage, the braking surface should be at the bottom so it rests on the shelf flat surface.
