Originally Posted by nicecar
the dash speakers are new, no chance for reverse polarity....harness connections oem. I will check the door connection and then the amp. I will forego taking off the door card. Thanks, any easy test for the amp right channel? Does the amp only run the door subs?
If you changed speakers always chance of reverse polarity by accident.
Anyway, the plug on the big plug on the amp has the several pairs of twisted wires those are the speaker wires. The violet color goes to the right door. This link has a diagram with the colors
https://cai-store.com/pages/996-c4-amplifier-installation
The small connector coming into amp is the control line and line level from head unit.
Becareful on the large connector there is a power wire that is always hot.
To disconnect the large connector it has a slide motion while pulling best way to describe it.
BTW really easy to remove door cards, get a set of plastic trim tools.
