You'll need the pinouts but one way to check connections is to disconnect the Amp connector and locate the correct pins for the right speaker. Take a 9V battery and briefly touch it between the +/- speaker connections. You will hear a 'pop' from the speaker. Polarity does not matter and you will not damage your speaker. If you hear a pop, your issue is amp or head unit. If you don't hear a pop, its time to trace the wire to the speaker.
