Old 05-06-2018, 04:43 AM   #2
Cunningr
Cunningr's Avatar
Trying to remember, but I think a bad heater coil can cause that to occur. The seepage of hot water mixing with the cold ac makes a fog or smoke come out the vents. If its odorless then another possibility is a stopped up drain hole.
However, some much smarter mechanics will chim in here. Good luck. Check see if your enging coolant droped might help identify a leak if the coolant dropped.
