Old 05-04-2018, 01:52 PM   #4232
The Radium King
The Radium King's Avatar
Finally seated the passenger side latch.. but the driver's side latch is being stubborn. I push the latch as far as it will go down... try to secure it with the handle... don't want to break it. Ideas?
Thank you.
determine why the latch doesn't want to close - broken, crud in the receiver, or if it is under too much tension to close. to confirm the first, unscrew the latch from the humps and see if you can get it to close ok. if it closes ok then the issue is too much tension - you can shim the latch, or get at the receiver and adjust it upwards (two screws with a lot of stuff in the way to make it not easy).
