Old 05-03-2018, 04:55 PM   #1
Spinnaker
Spinnaker's Avatar
Take off the gas (petrol?) cap and listen at the fill neck for a whirring sound when the ignition is turned on. If there is no sound, then the fuel pump is not working. Check the fuse first.
When the engine is cranking, does the tachometer show any revs? If not, then the crank position sensor is not working.
