Thread: Brake Pad Info
Old 05-01-2018, 05:55 AM   #4
Lemming
Lemming's Avatar
Originally Posted by AZ986S View Post
From what I know, you will upset the front/rear braking balance when using different pads for the front and rear (unless that's what you want).
I started out using Hawk DT60's both front and back, but did not like the setup, too much rear brake bias with the stock MC. This could be due to changes in weight balance (SPB) as well as running a square wheel/tire setup. Once I dropped the rears to a less aggressive compound (Blue), the car was much more stable under hard braking.
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
Lemming is offline   Reply With Quote
