Today I woke up at 5 am. and went out to the garage at 6 am. I was not looking forward to crawling back under the car this morning because my back was aching.
I acomplished quit a bit today. Installed the drivers side plugs, fuel filter (kinda a pain in the butt) zip tied some air condition and water lines out of the way. Next I tightened up the SC unit and now its in final resting position. Installed three more pieces of duct work (see pics) this means I have only two to go. Rerouted the throtle cable under the manifold, extended the electrical wires 14 inches (6 total and soldered the connections) and reinstalled the trailing arm. I probably forgot a few things if I think of them I will post.
This had to come out.
This pipe had to come out.
Installed bypass valve on this pipe.
Had to remove this bracket from throtle body.
Two more pieces of duct work installed.
This is where I need to tap into fuel rail.
Throtle body repositioned, rewired and more duct work installed. My arms look like I got into a fight with a blender. Talk about tight clearances.
