Old 04-30-2018, 11:24 AM   #25
Dave80GTSi
Dave80GTSi's Avatar
Originally Posted by edc View Post
If it helps my car is only road use and I've fitted the cheapy aftermarket manifolds to both my Boxsters with no issues and a slight improvement both times. I saw your pics and saw that you had already removed them. That is the one part that normally deters people. The labor cost to remove them is often more than the manifolds themselves.
I assume that the comment above refers to the often encountered difficulty in getting the 6 steel manifold bolts out of the aluminum cylinder heads without snapping them off?
If so, having the bolts out thus offers the perfect occasion to replace the lot of them with M8 x 42 mm long studs and matching SS flanged nuts
Years from now, whoever might have any need to remove these manifolds will thank you for your efforts to "stud" them today!
Cheers - DM
2000 Ocean Blue Boxster S
1980 Ferrari 308 GTSi
2019 Alfa Romeo Giulia Ti Sport AWD
Dave80GTSi is online now   Reply With Quote
