Thread: Brake Pad Info
Old 04-30-2018, 09:01 AM   #3
AZ986S
AZ986S's Avatar
Originally Posted by Racer Boy View Post
I kept the old set of Reds on the rear just to be safe, and they do shudder when hot ...
From what I know, you will upset the front/rear braking balance when using different pads for the front and rear (unless that's what you want). Personally, I've use EBC yellows on all 4 and the balance and bite is excellent for track days. The yellows do need a little heat to be effective meaning you will initially need more brake pressure when using the car on the street and for the first lap or two. They also dust a lot. I'll be switching to my summer street pads here after the last event at AMP on May 20.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
