Old 04-27-2018, 08:59 AM   #19
911monty
911monty's Avatar
Originally Posted by mikesz View Post
@911Monty What should I look for as far as damage from bottoming out? There was no leakage when I swapped the H&R for stock springs. They look brand new. I would think damage would show some leakage from the top seals?
Mike, You're fine. Your shocks were designed for the full travel of the stock suspension. The damage I referred to would be internal. Can happen on slammed cars using non stock components that have significantly altered suspension travel causing the shocks piston rod and valve to be the limiter on full compression. Guess I only brought up to emphasize the suspension should be thought out as a system designed for an intended purpose instead of just mix and match parts, especially now that these cars are so cheap that we are seeing modifiers going for look instead of purpose.
