Old 09-05-2006, 12:21 PM   #1
KRZTACO
Hi Randall,
Just to give you some more FACTS before you make your decision...
Magnaflow Performance Exhaust gives away a FREE Exhaust as a thank you for helping them produce a cat-back exhaust system.
What usually happens is the consumer releases the vehicle to MF for testing. MF has the car fo about 3 business days and runs an initial dyno on the car for a baseline. Then MF designes and fabricates the Cat-back system. After that, a JIG is built so the kit can be replicated for production then the car is given back to the consumer with all OEM Parts and the new MF kit installed. The car with the kit is then dyno proven to confirm positive results. After a week or two the new cat-back system produced from the jig is test-fitted on the original vehicle which takes just 1 day. A rental car is available at NO CHARGE for the consumer at any time...no hassle.
At the end of the day an automotive enthusiast gets a FREE dyno proven exhaust system and a rental car to use while the vehicle is at MF.
Out of Pocket costs: $O
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
