Old 04-25-2018, 08:34 PM   #1
AZ986S
AZ986S's Avatar
NHP headers sound great!
Tried out the new NHP headers at the Bondurant Track with the NASA bunch. This is the full length 1.6 mile config with the carousel, and is a very technical track. The car felt strong. Got some more oil pressure data with the Accusump too. It is starting to get hot here in Arizona so only one more event at AMP in a couple of weeks...
The oil temp did get up to 240F. That is the highest I've seen it since installing the gauges and data logging.
https://youtu.be/BXPxl4q8SL8
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
