Old 04-25-2018, 06:33 PM   #17
Racer Boy
Racer Boy
Racer Boy's Avatar
Originally Posted by Booker42 View Post
Success, used Gilles Dremel idea for the bottom two bolts and used brute force to break the top bolt with a 13mm socket and a breaker bar. After that, the job was easy. After reading several post on the subject, I got the 2" Easy Clamps and they worked great.
Thanks again to all for the help!
I just installed the non-resonator Circuit Werks pipes, and the passenger side stock pipe was a nightmare to get out. I too ended up cutting the clamps to get it apart. However the 2" Easy Clamp was too large and didn't work. How did you get yours to fit? I ended up getting the stock clamp from Pelican.
The driver's side was a breeze, only taking me about half an hour to replace. The clamps and pipes weren't rusted like the passenger side.
It does sound better, but it's pretty subtle. Hardly louder than stock, but the tone is better. I'm not sure why you would need the resonated secondary pipe.
