Old 04-25-2018, 03:10 AM   #11
RG2000S
rggav
1st time cable ball removal
Originally Posted by Geof3 View Post
Why did you have a tough time with the ball sockets? All they do is hold down the water barrier. Remove only the end at the top. They pop of very easily. You didn’t try to remove the red ones did you!? They are the ones connected to the actuator for the top itself. No need to remove if you did.
The cables are short so you can't raise the water barrier high enough to see them. I had never seen the little pin that holds the ball in the socket. Finally realized that you unclick pin from bottom of ball, rotate and remove pin. Ball was kinda hard to remove from socket after I removed pin. I had to put the pins back in by feel but I got them in.
The next time it will be a lot easier.....newbe problems 1st time.
RG2000S is offline   Reply With Quote
