Old 04-24-2018, 08:56 AM   #1
Deadeye
Hey Quad, I read your thread and saw that Softronic reflashed yours and cured your problem. Mine is not the same time dependent issue as the first time it was about 20 min and the second time closer to 15 min. Jorge at ECU Dr. in FL flashed mine to row specs and raised the limiter a bit. I would think if it was a problem with the flash, it would have showed up some time ago. My current theory is a bad servo at the throttle body, but not confident in that. I'm going to check the output from the pedal as well.
Deadeye is offline   Reply With Quote
