Old 04-23-2018, 10:07 AM   #4
BirdDog
BirdDog's Avatar
Just remove the spoiler cover and reinstall it.
It's held in place on the front by 3 (I think it's 3, might be 4) plastic rivets. You just press the center pin of the rivet in all the way (it will fall down below - be sure to find it - you'll need it to reinstall the rivet) and then pry the rivet out using your fingers.
Once the rivets are out, you should be able to easily remove the spoiler cover.
Then reinstall the cover, first hook the back of the cover over the back of the spoiler, then roll it forward and snap the front down. Then reinstall the plastic rivets by inserting the rivets, then inserting the center pins. Press the pins in until they are just flush with the top of the rivet.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
