Old 04-20-2018, 11:40 AM   #14
Brian in Tucson
Originally Posted by Doug427 View Post
I hate to say it, Brian, but it's looking more and more like this is the only answer - do it myself. I can't tell you how much I DON'T want to do this. I still love tinkering with cars, but my heavy work job days are well past me. I used to swap engines in my younger days on a moments notice, but that was American muscle cars and front engine cars. This is my first mid engine car that drops out the bottom, and I'm not looking forward to that at all. If this were one of my old Corvettes or my current Cobra, the engine would be out already. I have a very complete set of tools, and even a 4 post lift at home. I'm not home now, I'm traveling for work, so I can't look, but my question is has anyone dropped an engine out of a Boxster on a 4 post lift? Will the engine fit down through the two main ramps that the car sits on? If it will, then this is instantly a much more palatable job.
Laying on my back doing this is a much different picture. My 60 year old body has a bad back that I deal with daily, and my energy level is somewhat depleted by a past dance with chemo and radiation. No whining, it just is what it is. For the actual dropping and lifting moments in and out, I'd need a second set of hands, which aren't readily available to me, but I can probably drum up someone for that. The guy I can probably get to help me for an hour to drop and a hour to get it back up to the car doesn't know a lug nut from a steering wheel, but I suppose he really doesn't need to.
I'd be much more willing to do it myself if I could do it on my four post lift. If any one knows for sure if this can or can't be done, please let me know.
It drops straight down, the widest part of the engine is up around the plenums and the cam covers. If it will be able to drop down between the rails on your lift, you can lower it down onto the top of a lower tool cabinet, finish disconnecting the trans mounts and the motor mount and then raise the body back up enough to clear the engine.
I did mine the third world way--adlibing as I went. If I were in worse shape and had a lift, I'd probably scan craigslist for a Mexican guy to do the heavy work. There are some really competent Mexican Mechanics that don't charge an arm and first born to work for you. At least here in Tucson there are. Having a helper would be as good as having a lift.
2001 Boxster
2007 Toyota Highlander
