Old 04-20-2018, 06:32 AM   #13
Doug427
Doug, I used one of these to remove the gearbox and also to lower the engine to seal a leaking cam cover (using jack stands..)
https://www.harborfreight.com/1000-lb-capacity-hydraulic-table-cart-60438.html
I believe that you can easily position this table (or something similar) between the ramps on the lift and once you remove the mounts, harness, hoses, etc., you can raise the car and leave the engine/gearbox laying on the table.
I really wish I had a lift..
I guess it all comes down to if the engine will fit between the ramps on the lift. Thanks for the heads up.
Doug427 is offline   Reply With Quote
