Old 04-20-2018, 06:04 AM   #12
Gilles
Originally Posted by Doug427 View Post
I have a very complete set of tools, and even a 4 post lift at home. .
Doug, I used one of these to remove the gearbox and also to lower the engine to seal a leaking cam cover (using jack stands..)
https://www.harborfreight.com/1000-lb-capacity-hydraulic-table-cart-60438.html
I believe that you can easily position this table (or something similar) between the ramps on the lift and once you remove the mounts, harness, hoses, etc., you can raise the car and leave the engine/gearbox laying on the table.
I really wish I had a lift..
