Old 09-04-2006, 05:21 PM   #10
ohioboxster
ohioboxster's Avatar
Update with pics.....
I started about 12:30 today and by 2:30 I had the SC unit in place. Then it came to direction #5 on my install guide...Snake pipe 4 up through engine and chasis. It should have said draw a pentagram on the ground and sell your soul. The one pipe you can see through the wheel well took me 4 hours to install, hmmm I guess thats why its called pipe #4. One of the bolts took forever ! No room for a wrench or socket. I changed the 3 plugs on the passanger side today. I need the proper water fitting (see pic one) for the line that needs rerouted. Tomorrow is another day....
Water line...
Take this off, rear cross member.
Remove this bolt to swing trailing arm out of the way.
These are the bolts that you take out to mount the SC braket to....
Replace bolts with studs use antiseize.
2002 TT
ohioboxster is offline   Reply With Quote
