Old 04-19-2018, 04:09 AM   #15
Cunningr
Cunningr's Avatar
Originally Posted by Stiglitz View Post
I used template provided on this thread as my starting point.
Many different materials have been used by different users, since I was verifying it worked first, I actually used the top off an old sterilite storage bin. Traced it out, used a box cutter new fresh razor blade (only cut myself once!).. cut outside the lines first, then trimmed-fitted as needed. Scuffed up with scrub pad, and sprayed black.
For the covers, I used (much like many others) an IKEA trash bin. Thankfully I have an angle grinder, which made cutting a trimming much-much faster than having to do it with tin snips or wire cutters!
Scuffed and trimmed, painted black, clear coated, hot glued in. Still pretty visible inside, so I put some black screen material behind it. Came out pretty nice!
I'll post some pics tonight if I have a chance.
Cool. I have a PnP kit but I am not going to install it, I did new 3 way components 6.5" 3", 1.5" and a pioneer PRS 80 HU. I set it to network mode Tweeters are power off HU Hi out, have the RCA mid running to the factory amp, as is sounds excellent. Have an Alpine amp and a 8" floor sub going in to finish.
