			I've bought several things from them and NEVER had a problem.
I always recommend trying Woody (ItsNotANova on here) first, and then QualityPorscheParts (on ebay) if Woody doesn't have what you need.
For many parts they will usually post a picture (or link) to the car that the motor came from.  You can see what kind of damage the car sustained that caused it to be taken out of service.  It will also give you the VIN number of the donor vehicle.
You can use the VIN of the donor vehicle to run a CarFax.  That might give you a bit more history and provide a clue about what kind of care the prior owner(s) took of the donor vehicle.
You can also use the VIN to determine if the motor ever had an IMS upgrade (via the lookup on the LN Engineering website).
				2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
