Old 04-14-2018, 06:06 PM   #146
78F350
Motorist & Coffee Drinker
78F350's Avatar
I had a good drive today. Put over 150 miles on it. It felt good. My daughter and I went to the car detailing clinic with the Porsche club, then visited my son and grand daughter near Tulsa. The only problem with the car was that the heater was blowing cold air and the outside temperature was in the high 30s. The best remedy for that was closing the vents and turning on the heated seats. I think the mixing door for the heater is jammed.
The check engine light from last night was legit, but easy to fix. The bank 2 primary O2 sensor was failing. Maybe residual from the flooding – I don't think I ever cleaned that sensor. It took less than 15 minutes to jack up the car and replace with a 'gently used' one that I had on the shelf.
My daughter and I refueling the SE and THAT:
I am starting to feel that the basics of this car are sound now, but there is still a long way to go to consider it recovered. I still have lots of simple things to do, like replace the wheel center caps and reinstall the original steering wheel. As I continue to clean the car, areas I have not addressed yet really stand out. I also have some major things to take car of such as the dashboard and pulling the carpet out to dry it completely (underneath).
