+1 on the ignition switch. You cannot push start the car if the immobilizer isn't responding, the ecu will not fire the injectors.
To double check short the start lock relay in the rear trunk. Relay #7 bottom left.
This will allow the car to crank without the immobilizer signal, if the car cranks and fires, its likely that relay gone bad. If the car cranks and doesn't fire, its the immo. If nothing changes, ts the ignition switch.
