Old 04-12-2018, 07:44 PM   #1
harrg67
Well, I pulled the seat out and popped open the waterproof case. I don't think they sealed it correctly, plus the silicone that should have hardened was soft everywhere but right around the cable bundles. The strangest thing was that the whole board was wrapped in a ziploc bag, with wire ties tight around the two cable bundles coming in. There wasn't any water in the case, though. The board itself has issues. The connector for the fuse cable came apart as I moved the connector around. It appeared to be loose when I opened it up. There are also some possibly damaged chip leads on the board. Definitely not in good shape. So now to send to the original repair company or find a better one.
harrg67 is offline   Reply With Quote
