					Originally Posted by flete25  Check
 1. Inmobilizer fuse
 2. Check the clutch ignition switch..bihind clutch pedal
 3. Check the ignition switch
 4. Check ignition relay in rear trunk
Thank you.
1) Fuse is okay.
2) I will check the clutch switch. Can you just jump the terminals to close the circuit for the test?
3) I have a replacement coming in, will try to test it, though. Other things that rely on the acc position work (ie. the top)
4) Can't get there yet, but I want to check that.
