					Originally Posted by particlewave  Not likely.
 Pull the immobilizer and have a look. You really need to get the front trunk open first so you can disconnect the battery (if you absolutely can't get to the battery, at least pull fuse C3).
 Most likely have corroded connectors on the immobilizer (immobilizer replaced, but they never cleaned the connectors...happens a lot).
Thanks, I will try that. I have been trying to get to the front latch from the bottom but haven't gotten far. I tried the jumper post in the fuse box but that didn't allow anything to open.
