Old 04-10-2018, 11:33 AM   #1
particlewave
Originally Posted by gabedrummin View Post
Sounds like a bad starter.
Originally Posted by harrg67 View Post
Even with the non-functional windows and hood/trunk switches and the fob that's not doing anything?
Not likely.
Pull the immobilizer and have a look. You really need to get the front trunk open first so you can disconnect the battery (if you absolutely can't get to the battery, at least pull fuse C3).
Most likely have corroded connectors on the immobilizer (immobilizer replaced, but they never cleaned the connectors...happens a lot).
