Old 04-08-2018, 02:23 AM   #4136
Cunningr
Cunningr's Avatar
I worked on audio system upgrade. Finished dash speaker components all mounted and tested.
Installing hertz mille 3 way system. Dash 3” mid and seperate tweeter. Used cai adaptor ring for 3” the tweeter became a pain. Ended up make 4 small holes in grill frame used 2 wire ties to make straps, then cut the head off 2 more to slide down to hold in place, 3rd around just to keep things sung and some electrical tape to seal around edges. Not ellegant put affective and out of site.
Ran speaker connections for tweeters to head unit, they will use the amp from the head unit. Mids currently running off stock porsche amp. Did a test with new head unit even not being tuned or having the low frreq outputs connected dystem already sounds much better.
Finishing door boxes for 6.5” speakers this week and finishing conectoons for replacment amp.
