Old 04-07-2018, 01:43 PM   #11
Cunningr
Cunningr's Avatar
Originally Posted by Stiglitz View Post
Anyone ever put a micro amp in center of rear console to drive the rear speakers? Would just need a 12v accessory power. A 100w amp should drive the two 3.5's pretty well.
Any comments are appreciated!
Have not done this but if you put a 100 watt amp there you would need a larger power line from the battery and a remote power wire. Easier to run speaker wires from the frunk to the rear speaker shelf.
Other option without knowing your setup use a 6 channel amp from a 996 cadriolet.
Or go full after market set up.
