Old 04-06-2018, 11:08 AM   #12
Wangta
Wangta's Avatar
Originally Posted by NVYELLO View Post
It is most likely the door latch due to a failed micro switch in the latch itself. The newest update from Porsche has a changed design for the switch contact that looks as if the problem should be slowed down or maybe even stopped. I just did mine last weekend for the same thing. I pulled the old one out and installed the new one in about 30 minutes. No special tools needed. A #2 Philips screw driver, 4mm allen, T30 torx driver, 8mm triple square and a 10mm socket on a 1/4" driver. An interior pry tool set wouldn't hurt either.
PM me if you need some help or a step by step walk through. It is not hard though if you have any mechanical abilities.
-Ed
Do you happen to have the part numbers for the new actuators Ed? And where did you order from? thank you!
2001 Porsche Boxster S Tiptronic
Wangta is offline   Reply With Quote
