Old 04-04-2018, 12:31 PM   #1
Cunningr
Cunningr's Avatar
Radio bracket question
Ok have instructions from cruthchfield watched numerous videos. Is it possible that my car has a factory radio with no frame installed? Only metal frame i see is one about 6 or 8 inches back held in by 2 torx screws either side, only way to remove it would be to take all the ac control surroundings out. It looks to me like my single din would slide into the bracket. Other issue the mounting ring with replacement feels just a bit wide for the hole, is this normal? Wasnt really planning on filing anything.
Update on project:
Left door speaker box finished except mounting speaker and making air holes
Dash speakers, 3 inch mounted need to solder connector
Tweeter pain in arse, needs better mount solution using wire tie as a strap to hold in place until i can find a better solution. Its a 41mm tweeter
Need to run wire for tweeter to hu location.
Alpine amp on hand with cai mount plate
Factory interface soldered up and ohm tested.
996 pasenger sub box waiting on 8” pioneer that a guy is going to mod into the box for me.
Conclusion
Project probably over skill level, so testing my patience.
