Old 04-02-2018, 10:11 AM   #18
Quadcammer
my anti gravity skills are legendary.
In actuality, if you've ever done any car wiring work, this is straightforward.
If you remove the cover of your sun sensor front and center of the dash, you'll see a hole for the wiring harness.
Remove your radio and hvac system, get your hand back there, and start feeding the wire up from behind the lower console.
Then starting from the top of the dash, drop a feed wire down until you see it by the center hvac vent. tape your sender wires to that feed wire and pull it back out of the dash.
From there you can do the same for power and grounds. Then just wire up.
I attached to dash with heavy duty velcro and a few spots of butyl just to keep it from vibrating.
