Old 04-01-2018, 11:24 AM   #3
Geof3
Originally Posted by rp17 View Post
You can reuse the coolant like you stated. I would drain it all in a clean bucket and use distilled water to check for leaks.. remember to use a new washer on the coolant drain plug. then drain and add the expensive stuff. Bout to do mines here in a couple weeks or so.. keep us updated.. What pump are you using? I'm using a pump from Fcp. Free replacements and sounds good for this application. Pierburg if not mistaken.
Others may add to this. Few threads already...
I’ve already got Porsche blood in it, so that’s easy. No other leaks either. I’ve read that a tiny bit of seep from the pump is “within specs”. Whatever that means. I think the most challengeing part would be transferring a bucket full of coolant to some other container. Or, just buy a pump and call it good. I will most likely go Pierburg or just do the Porsche pump, Suncoast has them on sale for 260.00. And of course do a low temp thermostat while I’m there.
