Old 04-01-2018, 07:58 AM   #16
Dr Feelgood
Originally Posted by Weevic View Post
Hi did you do the conversion in the end ?. I have a 2004 S & have seen a fantastic kit made by Anu Dimension. It looks great in the flesh & costs £5,300 to buy plus lights & other bits. Or you can give your car to them & they will make the car to your spec for £20,000. That’s finished any colour .
No i ended up not getting the kit. Just seemed like a large expense for a kit that would probably crack on the rough roads here and the car is up there in miles as well. The kit you are referencing is even worse as it is even more expensive (if you convert to USD it's $28,000 installed) and makes your car into a hard top which completely defeats the purpose of owning a boxster.
Dr Feelgood is offline   Reply With Quote
