Old 04-01-2018, 03:52 AM   #15
Starter986
1998 Boxster Silver/Red
Originally Posted by 986bsdriver View Post
Hate to bring this thread back from the dead. I found some 18x11 rims with a 45 offset and 18x8 with 50 offset. Pretty sure the fronts will fit without an issue. The rears is why I’m bumping this thread.
From what I got out of this thread is that I will be needing a minimum of a 13mm spacer so it won’t kiss the struts in the back. When I use a spacer of that size, will I also need to buy extended wheel bolts to accommodate the spacers? Same goes with if I were to use the 5mm spacers they come with for the front as well?
Yes.You will need longer bolts. Certain manufacturers include the bolts with the spacer.
1998 Porsche Boxster
