Old 03-31-2018, 05:55 PM   #5
Geof3
I’m pretty sure those vanes in the front rotors are direction specific. Every single brake rotor (maybe the solid discs are an exception) I have ever seen listed are L R with different part numbers. The holes should sweep in the direction of rotation. And as mentioned, the stance does look cool, which is a bummer because driving over any bump would be challenging! I’m thinking springs are the only way to fix that correctly. As you purchased them used, the springs just might be dead. Or the compression dampening is shot.
