Old 03-27-2018, 07:42 AM   #12
Burg Boxster
Originally Posted by Stiglitz View Post
Thanks for the quick response, Burg Boxster. Going to look at OEM 6 ch and aftermarket. Guess have to find a wiring loom for it (I hate having to tap or splice into wiring.
Why? Wiring is same - even connector.
Look at your existing amp plug and you'll see there are [at least] 4 open pin locations for to accommodate leads for rear speakers. You just run the leads from your rear speaker [kit] to the amp. Slide the pins to correct location in harness (5/15 and 6/16 are for rears but order depends on if 996 or 986 amp as I recall). Then drop in 6x40W amp to exact same location (it's identically sized as 4x40) and Boom - Bob's your uncle!
Good luck
"Cool Prius!"
- Nobody
