Old 09-01-2006, 12:02 PM   #5
rbhlaf
TSB's performed and oil pump seal
TSB:
W573 - This is the retrofitting studs for the engine carrier with caps.
W572 - Rubber Buffer Draft. not sure what this is.
When they got to the motor it was obvious there was oil coming from somewhere, turned out to be leaking between the oil pump and the block. They replaced the rubber o-ring and rubber gasket. Service guy said they never had seen it before – just my luck. Glad I took it in early for the oil change.
’06 987S Arctic Silver/Terracotta/19's
’02 Tundra
’06 Specialized Roubaix Pro
rbhlaf is offline   Reply With Quote
