Old 03-26-2018, 06:00 PM   #9
Burg Boxster
Can you? Yes.
Ok to? Yes.
Recommended? Not so much.
Why? The OEM h/u is only 18W (maybe 20W) per channel versus amp @ 40W. So you will have an automatic imbalance there... The imbalance is fine electrical-wise but effectiveness of your rear speakers (which candidly is already low w/ 2.5-3" drivers) will be greatly reduced assuming equal sensitivity, etc.
Running wires from rear to up to the dash is the harder part. Thru the firewall to amp is a piece of cake - the grommet is there just a quick "x" cut w/ a utility knife. Suggest you either find a 6x40W amp from a 996 or one from another 986. From there it's a quick drop in. Otherwise, replace w/ an aftermkt amp (my recommendation - though OEM will be sufficient)... (If you haven't already, replace the garbage component speakers Porsche stuffed in the dash.)
You're doing all the hard stuff to make audio system a much better sound stage... don't cut an easy corner as it's effectiveness is equally if not more important (and you'll most likely double back later and correct...).
Good luck
"Cool Prius!"
- Nobody
