Thread: Part ID
Old 03-25-2018, 03:00 PM   #2
BirdDog
BirdDog's Avatar
Hang on a second... I replaced one of those on my 2001 S... (pretty sure it's the same part, but I'll double check with the PET)...
Pelican's website calls it a "mug guard". When I ordered it from them for my car 5 years ago it was called a "Floor Cover Trim, Black, Left".
Here's the current part numbers from Pelican:
986-504-393-00-01C-M100 (left side)
986-504-394-00-01C-M100 (right side)
If you order it elsewhere, just drop the "-M100" - that's Pelican's supplier code.
To replace it, jack up the car, remove the wheel (for working room), and remove the wheelwell liner ( 2 or 3 10mm plastic nuts). Then it's 3 or 4 philips or hex headed screws (two or three underneath, one under the wheelwell liner that attaches the mud flap to a bracket).
If you ever rip up just the rubber part on the bottom, you can order that separately (but it comes with the new mud flap).
Hope this helps!
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
